January 29, 2019 at 3:38 pm
Adisa
SubscriberHello anyone,
I have the experimental date of PC material (plastic), from tensile test I got force-displacement, when It converted in the engineering and true stress, I got that the true stress falls. As we know that in Ansys can not be input decreasing stress, can anyone help me with this problem.
First I think that this true stress strain use for the pipe specimen with diameter of 12,5mm, Where I need the max force which pipe can endure during tensile test. And I got that is about 1800N as in the below pic.
Second I think to use true stress strain for drop test, where need to determine when the plate (500x500x15) will break (when strain is about 1mm/mm) if on it drops the sphere of 0,5kg.  The plate is of the same material as the pipe, PC.
January 29, 2019 at 6:49 pm
peteroznewman
SubscriberPlease give more details about the material. Is it a fiber reinforced material?
January 29, 2019 at 9:12 pm
Adisa
SubscriberPeter, I use this video of tensile test as the experimental test:
https://youtu.be/z9mDVsaVyxIÂ
In the test is used the specimen of PC without fiber reinforced material. I think that fiber reinforcedÂ
 materials do not have so much elongation as well materials without reinforced. Am I right?
Did You have any example where the true stress decrease of any material, If yes, How did you input it in Ansys.Â
January 29, 2019 at 9:49 pm
peteroznewman
SubscriberNecking of the specimen occurs during the test. Once necking begins, the displacements beyond the point at which necking began cannot be used to create Stress-Strain material data because the assumptions of uniform plasticity are invalid and the conversion of Engineering Stress and Engineering Strain to True Stress and True Strain becomes invalid.
January 30, 2019 at 9:27 am
Adisa
SubscriberPeter,
Yes, the necking occurred during the test.
Thanks for the information. Which the parameters from material needed to be used for determination when the part will totally separation. I attached data sheet of the one another material which has all parameters which some of them maybe can be used for drop test for determination separation. I sent this as example not the parameter of PC.
Did You have any suggestion how to simulation drop test with this material, where I need to determine the dimension of ball steal which will cause totally separation of the plate (500x500x15).
I can not tell that when occur the necking that the construction will the totally separation, only in that point is the necking?
January 30, 2019 at 6:33 pm
peteroznewman
SubscriberLook for another PC on Campus Plastics that has a Stress-Strain diagram.
Click on Control Points to get the Excel numerical data.
Convert this Engineering Stress-Strain data to True Stress-True Strain for use in a Multilinear Plasticity material model.
Regards, Peter
January 31, 2019 at 12:36 pm
Adisa
SubscriberPeter thanks,
 From the above stress-strain diagram for temperature 23C, at stress 62.9 and strain 7.5%, I can guess that will occur the totally separation of the part during drop test, or ?
January 31, 2019 at 7:39 pm
peteroznewman
SubscriberThe above plastic stress-strain curve is up to the point of Yielding. Perhaps this is where the necking begins.
Here is another plastic that shows the strain at break is 30%, but this plastic doesn't have a Stress-Strain diagram.
Another property of plastic is strain rate sensitivity, so the elongation at break might be function of strain rate. In other words if the material is stretched at 0.1 mm/sec it might get to 30% strain when it fractures, but if the material is stretched at 100 mm/sec, it might only get to 5% strain when it fractures.
Can you run your own samples at your own settings in the Tensile Testing Machine?
Regards, Peter
February 1, 2019 at 1:11 pm
Adisa
SubscriberPeter thanks for the information,
I can not run samples in the Tensile test machine, I only use the online properties.
I thought whether the properties from tensile test can be used for the drop test, because the strain rate during the drop test I did not know in advance.
Peter now I did not know which the parameters use at the drop test, I am confused.
So far, I used the parameters from tensile test where I used the point of yield point as that the crack will occur.
Now, I did now know.
February 1, 2019 at 4:53 pm
peteroznewman
SubscriberHere is a very good article on strain rate and temperature effects on plastics. It says the low temperature properties of the material at low strain rates are similar to the high temperature properties at high strain rates. Maybe you can use this concept to get properties for your drop test simulation that will have less error to a physical test. Here is a polymer website that explains different types of stress-strain curves.
You need to know the strain at break for your material. Where did you obtain the data from your first post?
I looked in the Engineering Data library and found POLYCARB. It has a Multilinear Plasticity curve that goes out to a Plastic Strain of 0.7 and the reference given is S.M. Walley et al. "Strain rate sensitivity of polymers.." DYMAT Journal-vol.1-3-sept 1994. Can you obtain that journal article?
February 6, 2019 at 10:46 am
Adisa
SubscriberPeter,
I obtained the data from video which is attached at the second post (experimental results of PC). And that the break strain is shown in the pic.
- The topic ‘How to input true stress, when the stress falls’ is closed to new replies.
5884
1306
