December 11, 2023 at 8:49 pm
hansenli
SubscriberHi,
Is nodes to surface thermal contact supported in LS-DYNA. I received a warning:
*** Warning 20660 (STR+660)
in definition of contact 1
Contact must be surface_to_surface
for a thermal problem. This contact
surface will be skipped during the
thermal calculations.when I started the simulation. In this simulation, I was modeling the contact between tool and workpiece, where the tool is modeled using FEM, and the workpiece is modeled using SPH.
Thanks!
December 18, 2023 at 6:19 pm
Reno Genest
Ansys EmployeeHello hansenli,
There is the following information in the LS-DYNA user manual vol I:
If you are able to use one of the supported nodes to surface contact without specifying a node sets, then maybe it could work. Otherwise, I am not sure how you can define a thermal contact between FEM and SPH.
Could you use FEM instead of SPH in this case?
Reno.
- The topic ‘Node to surface thermal contact’ is closed to new replies.
6465
