January 16, 2019 at 1:49 pm
qdb15143
SubscriberHi all,
I've been attempting to model a piezoelectric bimporph with the ansys piezoelectrics and mems addon, and everything works fine (static structural, modal) untill i get to the harmonic analysis. At this point im never able to apply voltages to surfaces as this option is greyed out, the only option is Enforced Motion voltage, every time I use this option however my model won't solve for whatever reason (an error occured inside the solver module: general error).
I am new to this so even if you think your solution to be too obvious, please let me know nontheless.
Cheers,
Ben.
January 18, 2019 at 8:44 am
jj77
SubscriberI am not familiar with the specific act, but in the end of the day, act ext. run in the background apdl commands.
Thus you can put one in your self via the command snippet.
Before that, define two named selections of the positive (called positive say) and negative electrodes.
Finally apply a voltage boundary condition (via apdl commands) like this (800 harmonic voltage, and zero on negative, so grounded).
d,positive,volt,800
d,negative,volt,0
There is a video called: ansys cae 16 harmonic response analysis, for more details.
June 9, 2019 at 10:34 pm
Jkjkjk
SubscriberProblem solved mate?
I am having the same issue.
June 9, 2019 at 10:40 pm
December 27, 2021 at 4:09 pm
Syafiq1986
- The topic ‘Ansys Piezoelectrics and Mems expansion, cant apply voltage to harmonic analysis’ is closed to new replies.
6660
1313
