Photonics
Photonics
how to get transmission value using script
    • SAURAV GAUTAM
       getting T_avg as dataset not as scaler number.
    • Afroditi Petropoulou
      Dear Saurav,
      To get the transmission you can use the transmission command:
      T_avg=transmission("monitor_2");
      or you can use the following:
      T_avg=getresult("monitor_2","T");
      ?T_avg.T;
      Best Regards
      Afroditi
    • Dimitris Polyzos
      Thank you for contacting us. It would be helpful if you could provide a little bit more information regarding your model. However, I believe that you should use 2D monitor in your simulation to get a dataset of transmission similar to the picture below:
      I hope I helped. Please let me know if you need further assistance.
      Kind regards
      Dimitris
  • The topic ‘how to get transmission value using script’ is closed to new replies.
