LS Dyna
LS Dyna
Re: LS-Dyna k file syntax
    • Sa-aadat Parker
      The editor I am using to edit *.k files has a commenting keyboard shortcut. This works well with well-known programming languages. However, It does not recognise Ls-Dyna syntax. Does anyone know which language the Ls-Dyna script is based on? Which language uses a '$' sign to comment?
    • Jim Day
      LS-DYNA keyword file syntax is not associated with any standard programming language.
    • william shane
      There is no universally accepted programming language that uses the syntax of an LS-DYNA keyword file. run 3
  • The topic ‘Re: LS-Dyna k file syntax’ is closed to new replies.
