Electronics
Electronics
How to export Ansys Maxwell simulation results for post-processing in matlab or in .csv file
    • LiSsuJu
      Hi
      I am using Maxwell 3D with DC conduction solution type.
      I would like to export the results of electric field(E), voltage(V) and current density(J) to matlab for post-processing.
      But I don't know how to export it in .txt or .csv files.
      Hope someone would help me on it.
      Thanks.
      I think this is what you're after: I don't use Maxwell but do know (roughly) what to look for in the manual. Go to help and follow this:
      Maxwell Help > Working with Maxwell Projects and Designs > Exporting Files > Exporting Data Table Files
      Hopefully the community can assist further as needed.
    • raul.raghav
      Open the Fields Calculator. Select the Quantity you want to export. Then Export the quantity. Refer attached image for reference.
    • Raju07
      Hi Rahul,
      I have exported a field calculator data which is in .fld file. How I can open it and how I can use it to create graph?
      Thanks
      Raju
  • The topic ‘How to export Ansys Maxwell simulation results for post-processing in matlab or in .csv file’ is closed to new replies.
