December 3, 2023 at 9:27 am
Vincent Doan
SubscriberI'm just a beginner on Ansys, and I'm struggling with simulating a V-die sheet metal bending process.
Can someone help me on how to set up the contact and static structural ? Cus when i watched the tutorials on Youtube, some use joint but some use contact instead.Â
Also:
Can i get the resulted bending force after solving?Â
And what if i want to input bending force into the simulation?Â
I'm looking forward to hear your suggestion. Thank you
Vincent
December 4, 2023 at 8:45 am
ErKo
Ansys EmployeeHI
I would suggest to use explicit dynamics for this (static can not solve this).
See here for a tutorial:
https://www.youtube.com/watch?v=OfiEqS3RlXw
ALl the best
Erik
December 4, 2023 at 10:43 am
Vincent Doan
SubscriberHi,
Thank you for your suggestion. It went quite well. But the thing is, my sheet metal plate is too flexible, felt like rubber, is there anyway i can make it bahave like normal steel plate? And also, i want to input the force at the end of the journey, is it possible?Â
Thank you
Vincent
- The topic ‘Need help with V-bending simulation with Ansys’ is closed to new replies.
5834
1305
