November 29, 2023 at 4:07 pm
November 30, 2023 at 8:04 am
Mike Pettit
Ansys EmployeeHello,
You should be able to do this using Fixed Point Groups (available from Release 2022 R2). A Fixed Point Group allows you to create a circular pattern of fixed (anchor) points, at equally spaced angular intervals. You can then Duplicate the group, and apply an RZ rotation to the duplicates, to build up the anchor points for your mooring system. For example:
This was created using Fixed Point Groups without any need to manually calculate the anchor point positions.
Linear or rectangular patterns can also be generated, or you can import a CSV file of attachment point positions. Connection Point Groups offer the same functionality for Connection Points on the structure.
I hope this helps.
Mike
December 19, 2023 at 7:12 am
Abu Yusrah
SubscriberMany thanks, Mike.
Apologies for the late response. I am working on it
December 20, 2023 at 4:03 am
Abu Yusrah
SubscriberHello Mike,
I tried to lay my hands on some documents through the help menu but couldn't get a comprehensive guide on the Fixed Point Group.
I will be glad if you can direct me to part of the manual document or video, pls.
Thank you
December 20, 2023 at 2:57 pm
Mike Pettit
Please refer to section 5.6 Attachment Point Groups in the Aqwa Workbench User's Manual. This covers both Fixed Point Groups and Connection Point Groups.
You can add a Fixed Point Group to the Aqwa model by right-clicking on the 'Fixed Points' object in the Outline tree, and selecting Add > Fixed Point Group.
Cheers, Mike
December 21, 2023 at 6:23 am
Abu Yusrah
SubscriberThanks, Mike. I will explore this option.
- The topic ‘Specifying mooring line angle in ANSYS AQWA’ is closed to new replies.
- Is it able to solve turbomachinery using density-based solver in Fluent?
- Two-way FSI simulation
- Ensight Force_per_unit area_EV
- RIBBON WINDOW DISAPPEARED
- Fluent Meshing Error when .dsco not .stp
- Ansys Fluent for modelling Ocean Wave reactions to Wave Barriers
- Battery Pack cooling
- ISAT ABORT error
- UNASSIGNED INTERFACE ZONE DETECTED FOR INTERFACE…
4597
1495
1386
1209
