December 6, 2018 at 9:40 am
Max4
SubscriberHi,
I want to have different " Cell Zones " in the Cell Zones Conditions dialog box of Fluent like the exemple below. There are a Cell Zone for each typ of the mesh.
And we can display all the celle zones, below the fluid_stationary-prisms for exemple.
In my case, I want to differenciate two zones: first zone is the zone with the inflation, and the second is the rest of the mesh. I have seen that we can use the surface element of the mesh (red frame), but it is very boring to chose all the elements.
Is there any other solution to do that ? For exemple, is it possible to create two different sketches in DesignModeler and mesh them independently ?
Maxime
December 6, 2018 at 9:47 am
Keyur Kanade
Ansys Employeethis has to be done in meshing. if you have case file in fluent please use following steps.
in fluent you can use
define beta y y
switch to mesh mode
mesh/separate/separate cells by shape
switch to solution mode.
if this solves your issue, please mark this as 'is solution' to help others on forum.
December 6, 2018 at 9:53 am
Max4
SubscriberIn my case, I have create the sketch and the meshing, therefore I can do it in Meshing directly. And if possible, I don´t want to change the sketch, but just seperate the different meshing zones in Meshing.
December 6, 2018 at 11:51 am
Keyur Kanade
Ansys EmployeePlease use fluent meshing with steps given above.
- The topic ‘Cell Zone Conditions for the mesh’ is closed to new replies.
5874
1306
