Ansys Learning Forum Forums Discuss Simulation General Mechanical Air-blast load without using CEL approach Reply To: Air-blast load without using CEL approach
Jacopo Bardiani
Hi Chris, thank you for your reply!
Ok! But you mean a CEL analysis in Autodyn? Or I can create only the lagrangian part (structure) and then select the detonation point and the features of the charge?
