Ansys Learning Forum Forums Discuss Simulation Fluids Negative Cell Volume detected in Dynamic Mesh. Reply To: Negative Cell Volume detected in Dynamic Mesh.
Federico
Yes, if you want to use Unified Remeshing. Unless your displacement is small enough that Smoothing would suffice, but that does not seem to be the case for you.
