November 2, 2023 at 10:53 pm
Ami Bha
SubscriberHi all,
I was wondering if one can change the surface energy of solid materials in Ansys Fluent. I would like to increase the surface energy of Aluminum to make surface wetting possible when simulating with small water volumes.
I don't want to change the contact angles in the wall boundary condition but rather achieve surface wetting by changing surface energy of my metal. Also: I cannot find the surface energy value set for Aluminum in fluent.
November 3, 2023 at 1:54 pm
Essence
Ansys EmployeeHello,
You can try rasing the temperature of the solid either by fixing the temperature of the solid to a high value or applying the thermal BC (temperature or heat flux) to the solid wall to a higher value.
November 3, 2023 at 2:04 pm
Ami Bha
SubscriberThanks for your reply! But what is the surface energy of Aluminum in Ansys fluent by default? I cannot find it. And does using other metals (e.g. Nickel) automatically change the surface energy to the correct value which corresponds to the material?
- The topic ‘Surface energy of solid materials’ is closed to new replies.
4597
1495
1386
1209
