Materials
Materials
Topics related to Granta Design and more.
i cant use ACP Post
    • Mare Levin
      Hi, could you please help me, i created a model in APDL and use it as an external model in Workbench for static analysis, i want to use ACP (Post) but i cant drag the Solution=>Static Structural to Results=>ACP Post
    • Saumadeep Choudhury
      Hi Mare Levin,
      if you want to use ACP (Post) for the results of static structural, I would suggest you go through this Learning Forum Post: Cannot connect my solution from static structure to ACP (Post) (ansys.com)
      Saumadeep
    • Mare Levin
      Thank you for your reply, the problem is i don’t have a pre ACP, i used a external model from APDL, when i drag and drop the pre post (picture 1) i got (picture 2) and after connecting setup to model (picture 3), im not able to connect the solution to results
      Hi, can you please check in the Toolbox-->Component System. As shown in the image attached.
    • Mare Levin
      yes here
    • Mare Levin
      I think you misunderstood my question. What I meant by I don't have pre-ACP is I didn't use it, I used an external model from APDL instead because my problem was i could not create a p=sin(x)sind(y) pressure in Workbench so i used APDL to do so
Viewing 5 reply threads
  • The topic ‘i cant use ACP Post’ is closed to new replies.
