November 1, 2023 at 5:14 ambcchul1Subscriber
I am performing sensitivity analysis by connecting "AEDT" (Maxwell). to Optislang
Parametric analysis seems to be progressing one by one.
Is there a way to analyze multiple things at the same time? -
November 2, 2023 at 4:39 pmigandikoAnsys Employee
When you open the AEDT node, at the bottom of the window, click on show advanced options and try increasing "designs per execution". I hope this helps.
November 6, 2023 at 1:21 ambcchul1Subscriber
Thank you for your reply.
- The topic ‘Optis Lang – Multi analysis method’ is closed to new replies.
Ansys Innovation Space
- Multi-Objective Shape Optimisation of Tesla Valve
- Creating Fluent Web Apps using optiSLang 2021R2.mp4
- Adjoint Method for Optimising Diodicity of Tesla Valve
- How to access “OSL_DESIGN_DIR” Environmental variable?
- Output parameter as an exported text data file
- Response constraint not allowing structural optimization to solve.
- Setup Optimetrics at HFSS 3D Layout Design
- The trouble-shooting that using python to control HFSS
- Material parameter optimization
- DP0 The Design of Experiments component in Response Surface could not be updated
635
599
591
366
