November 7, 2018 at 4:55 pm
abbas
SubscriberHello
I am working on two-phase co2. In my study, Co2 as a supercritical enters into the vortex tube and there should be different phases. One in vapor co2 and other is liquid co2. In my RGP table, I generated two table, one for vapor and another for liquid. i know that there should be some liquid drop in the domain.Â
According to the following link: I should choose vapor and liquid materials, as well as a homogeneous binary mixture to define saturation properties. (step 2)
!EDIT: Removed LINK
So, when I choose for example co2 vapor, co2 liquid and co2mix (homogeneous binary mixture), I define three fluids. What should I do?
November 7, 2018 at 9:14 pm
DrAmine
Ansys EmployeeThe binary mixture is not required as phase. It is just required to calculate saturation properties. Define only two phases.Â
November 7, 2018 at 9:18 pm
abbas
SubscriberThanks for your help.
So, I should add CO2 liquid and CO2 vapor into the FLUIDÂ definition. So, how the saturate properties will be calculated?
Best regards
Abbas
November 8, 2018 at 7:04 am
DrAmine
Ansys EmployeeThey will be calculated via the homogeneous binary mixture you created.Â
November 8, 2018 at 1:50 pm
abbas
SubscriberThanks for your help. Therefore, I shouldn't need to add homogeneous binary mixture in the fluid definition and the solver find the homogeneous binary mixture in the materials section? And I don't need to define it anywhere else?
Best regards
Abbas
November 8, 2018 at 6:50 pm
DrAmine
Ansys EmployeeNo you do not need it in the domain definition. You Need just to create it as explained int axial turbine stage tutorial.
November 10, 2018 at 2:12 am
zhangguojie2015
Dear, sir, could you help me do a tutorial about the CO2 non-equilibrium? especially about the material defined.
November 10, 2018 at 2:18 am
zhangguojie2015
Hello
!EDIT: Removed LINK
could you help me do a tutorial about the CO2 non-equilibrium? especially about the material defined. Thank you ! -
November 10, 2018 at 9:06 am
DrAmine
Ansys EmployeePlease create a new thread for your question. Check at first the axial turbine stage tutorial.
- The topic ‘two-phase co2 simulation in cfx’ is closed to new replies.
5834
1305
