October 27, 2023 at 6:24 amKawshik NathSubscriber
I've designed a solar cell using wavy layer structure in Lumerical fdtd for optical simulation. And now i want to do electrical simulation in charge module but here i don't find the wavy layer structure like fdtd module. So, plz help me to find out how can i design a wavy layer structure same as fdtd in charge or how can i import the structure from fdtd into charge.
October 27, 2023 at 4:47 pmAmrita PatiAnsys Employee
October 27, 2023 at 5:52 pmKawshik NathSubscriber
Yes, I designed from object library in fdtd module. how can i do that in charge module as there is no object library in charge for that structures.
October 30, 2023 at 6:29 pmAmrita PatiAnsys Employee
Hi Kawshik,
The wavy layer structure group uses Surface Import, which is only available in FDTD and MODE. Let me see if we have any other options to do the same on CHARGE and get back to you on this.
Amrita-
October 31, 2023 at 1:53 pmKawshik NathSubscriber
okk. Please see this and let me know it earlier.
- The topic ‘Problem to design a structure in charge module.’ is closed to new replies.
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Trapezoidal ring
- Help for qINTERCONNECT
- Issues with getting result from interconnent analysis script
- Topology Optimization Error
- Edge Coupler EME Example Issue
- The two modes overlap the integral
1191
513
488
225
209
