October 20, 2023 at 8:30 amSoufiane El kabilSubscriber
hello,
I am using FDTD simulation to model samples with varying thicknesses. I would like to inquire if there is a method or a MATLAB script that can be utilized to change the sample thickness automatically, without the need for manual adjustments. -
October 20, 2023 at 5:28 pmAmrita PatiAnsys Employee
Hi Soufiane,
You can do that using the Lumerical Scripting Language, by writing the code in the Script File Editor. Lumerical offers a large number of script commands that can easily help you run/post-process your simulations. This will be the simplest approach in my opinion. You may refer to these introductory videos on Ansys Innovation Courses to get started: Lumerical Scripting First Lesson. Lumerical also offers Python and MATLAB Integration, please refer to the following links for more information:
But like I mentioned, the first option would be the most straightforward. And I feel the Lumerical's Scripting Language is very easy to use if you know MATLAB Scripting already.
Amrita
- The topic ‘Controll Lumerical by using Matlab or Python’ is closed to new replies.
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Help for qINTERCONNECT
- Trapezoidal ring
- Issues with getting result from interconnent analysis script
- How to measure transmission coefficients on a given plane .
- Topology Optimization Error
- Absorption cross-section of AuNR excited by prism-based TIR
1301
591
544
524
366
