Mixing Index of Multi-phase gas-solid flow
    • MohAgha1
       Dear All;
      Can anybody show me the fault in the setup of a user-defined function for calculation of the mesoscopic mixing index of gas-solid flow in fluent;
      hint: mesoscopic mixing index: define mixing status (mixed/not mixed) based on the volume fraction of solids in the computational cell
       my udf is attached
      it gives wrong results as shown in the following image
    • Keyur Kanade
      As ANSYS employee, we can not download attachments. Can you please insert image.
      Keyur
    • MohAgha1
         UDF for calculatin of solids mixing index of two-solid phases in a multifluid model
       #include "udf.h"
       real mix_index=0., Nt, Ni;
       DEFINE_EXECUTE_AT_END(execute_at_end)
          Domain *d, *ds1, *ds2;
          Thread *t;
          cell_t c;
          d = Get_Domain(1);      /* mixture domain if multiphase */
      ds1 = Get_Domain(3);  /* solid-1 domain if multiphase */
      ds2 = Get_Domain(4);  /* solid-2 domain if multiphase */
         thread_loop_c(t,ds1)
                 begin_c_loop(c,t)
          /*Thread **pt;   /* initialize pt   */
                /*  pt = THREAD_SUB_THREADS(t); */
                   C_UDMI(c,t,0)   = C_VOF(c,t);  /* storing the void fraction of the solid-1 phase for all domain cells in a user-defined memory */
                 end_c_loop(c,t)
         thread_loop_c(t,ds2)
                 begin_c_loop(c,t)
                    C_UDMI(c,t,1)   = C_VOF(c,t); /* storing the void fraction of the solid-2 phase for all domain cells in a user-defined memory */
                 end_c_loop(c,t)
         thread_loop_c(t,d)
                 begin_c_loop(c,t)
         printf("vof_s1: %fn", C_UDMI(c,t,0));
                printf("vof_s2: %fn", C_UDMI(c,t,1));
         if(C_UDSI(c,t,0) >=0.01)
      Nt = Nt +1; /* total number of solid-1 cells */
         if(ABS(C_UDMI(c,t,0) - C_UDMI(c,t,1))/C_UDMI(c,t,0) <= 0.1) /* condition of mixing */
        Ni = Ni +1; /* cells of mixing status */
                 end_c_loop(c,t)
      if(Nt > 0)
      {mix_index = Ni/Nt;} /* meso-scopic mixing index */
          printf("MI: %fn", mix_index);
    • MohAgha1
      I think the problem is because of the phases thread-identifiers
      I tried adding     "Thread **pt;   /* initialize pt   */
                  pt = THREAD_SUB_THREADS(t); "
      and referring to the solid phase threads by pt[3], pt[4]
      but it results in the following error after successful interpretation of the udf
      There should be a more useful error message at the start of the repeated 999999: mpt_accept lines.    I assume you've assigned the UDM storage in Fluent?
      Note, as staff we're unable to debug UDF's, so you'll need to (very carefully) read the manual and/or come for training.
    • MohAgha1
      Dear Sir;
      I read the related lines in the manual and I don't understand how to refer to the phases threads within the mixture loop in multiphase problems like the present one
      I saw this image can clearly illustrate my problem
      Now, I want to access the interaction domain and do some processes on the subdomain phases-threads
      Can anybody guide me to find the missing circle?
      Mohamed
    • MohAgha1
      Yes, you are right, but the fluent closes by this error before I can copy the full error specification
    • Keyur Kanade
      When you open Fluent, please use File - Start Transcript. Then after doing operations in Fluent, again use File - Stop Transcript. This will record all transcript and you will be able to see any errors.
      As rwoolhou  already mentioned as staff we're unable to debug UDF's, so you'll need to (very carefully) read the manual and/or come for training.
      Keyur
    • MohAgha1
      Dear All;
      Thanks for your interest in solving my problem, I succeeded to solve the problem here below attached my working-well udf to anyone who wants to use it
       #include "udf.h"
       real mix_index=0., Nt=0.0, Ni=0.0;
      cell_t cell;
      Thread **pt;
      Thread *cell_threads;
      Domain *mixture_domain;
      mixture_domain=Get_Domain(1);
      mp_thread_loop_c(cell_threads,mixture_domain,pt)
      begin_c_loop(cell,cell_threads)
         if(C_VOF(cell,pt[1]) >=0.05) /* Vol. fraction of the solid-1 phase */
         if(ABS(C_VOF(cell,pt[1]) - C_VOF(cell,pt[2]))/C_VOF(cell,pt[1]) <= 0.1) /* condition of mixing */
      end_c_loop(cell,cell_threads)
                printf("Nt : %fn",Nt );
      printf("Ni : %fn",Ni );
      if(Nt > 0)
      Ni = 0.0;Nt=0.0;
      Regards;
      Mohamed
    • Keyur Kanade
      Glad that it is solved. Can you please mark this as 'Is Solution' to benefit others on forum.
      Keyur
Viewing 9 reply threads
  • The topic ‘Mixing Index of Multi-phase gas-solid flow’ is closed to new replies.
