October 24, 2018 at 7:51 am
melalisa96
SubscriberHi
I want to view the safety factor for my model which I have conducted for static structural analysis. However, the error message "Yield Strength is required but not defined' kept appearing. Same goes for ultimate strength. How do I go about defined these 2 parameters?
October 24, 2018 at 7:59 am
October 24, 2018 at 8:04 am
October 24, 2018 at 8:05 am
melalisa96
SubscriberI have inputed the young's modulus and poisson's ratio for the materials that I used for my simulation
October 24, 2018 at 8:36 am
melalisa96
SubscriberI have also inputed the tensile yield strength and tensile ultimate strength for the respective materials but I'm not sure why I can't get the safety factor out as the same error occured.
October 24, 2018 at 8:40 am
Rohith Patchigolla
Ansys EmployeeCould you please click on the new material and look at this table.Â
I believe, they are greyed out, since they are already defined for the default material i.e. Static Structural.Â
October 24, 2018 at 8:45 am
October 24, 2018 at 10:07 am
Sandeep Medikonda
Ansys EmployeeCan you double check if the materials are correctly assigned to the details of the geometry? Click on the part of interest and check assignment?
Also, please post some snapshots of your structure tree if that doesn't work along with what you have in Engineering Data?
Sandeep
Guidelines to the student community -
October 25, 2018 at 2:16 am
melalisa96
SubscriberHi Sandeep
Yes, the materials are correctly assigned to the details of the geometry. However, I don't understand why is it that when I click on 'Stress Too'- 'Mohr-Coulomb Stress'- 'Safety Factor', the following pops up:
And when I clicked on 'Max equivalent stress', 'Max shear stress' and 'Max tensile stress', it shows me a safety factor of 15 for both max and min.Â
Any ideas?
October 25, 2018 at 4:22 am
melalisa96
SubscriberOh, and IÂ want to analyse the fatigue life of the model and the error- "An error occured inside the FATIGUE model. Invalid or missing stress life curve." pops up. How do I go about implementing the stress life curve or even correct it? Because I've inputed all material properties and matched them to the respective bodies.
October 1, 2019 at 8:14 am
NawafRasheed
SubscriberI've the same problem
October 2, 2019 at 1:26 pm
peteroznewman
SubscriberYou have to have a S-N Curve defined from the Life category of the Engineering Data toolbox. See Structural Steel for an example.
- The topic ‘Safety Factor Cannot be Viewed’ is closed to new replies.
6184
.jpg?width=690&upscale=false)
