Simulating the natural angular speed of a turbine using CFX
    • venkatesh.kanchendram
      Is there any method to find out the turbine speed for a given inlet conditions, using Fluid Flow CFX?
      I need to be able to visualize the rotation of the rotar, something similar to 6DOF in Fluent.
      FYI, I have used the method where we find the rotational speed by parameter method (assigning the rotation to turbine and finding the speed by extrapolating the net zero torque condition of the turbine)
    • C N
      Hello Venkatesh,
      I recommed you to create a speed line.Please refer this link on how to do it .
      11.1.3. Computing Speedlines for a Machine (ansys.com)
      I hope this helps you in your simulation.
      Thanks,
      Chaitanya Natraj
      I am not able to access this link
      could you please give me a work around to access it?
  • The topic ‘Simulating the natural angular speed of a turbine using CFX’ is closed to new replies.
