Ansys Learning Forum Forums Discuss Simulation Fluids modeling heat transfer considering thin wall separating two fluids Reply To: modeling heat transfer considering thin wall separating two fluids
I'm not permitted to download anything. It's one of the rules staff operate under to avoid any issues with Export Law.
Looking at the images you have a fluid & other zone. So we can see that's working. If there is no difference in result between setting a wall thickness or not, is that because the flow is slow enough that the fluid-wall thermal transport is the limiting step on heat transfer?  Remember, the overall heat transfer is a function of fluid1-wall, wall conductivity and wall-fluid2     I can't remember the equation, it's been a while!Â
