September 28, 2023 at 1:55 pmKIRTI RANJAN DASSubscriberThe software's solver is getting stuck in initializing the interface. I'm herewith attaching the screenshot of the error and also I'm not able to download any file from the Application Gallery and error message has been attached. The licenses menu has been shown with active as well as inactive license.Can anybody suggest some solution.
September 28, 2023 at 10:56 pmLitoAnsys Employee
@KIRTI RANJAN DAS,
Please remove the Lumerical product preference.ini files from your user folder on your computer. See this Knowledge Base (KB) for details/instructions.
Your IT/Network security is probably blocking access from our application to our servers. Try to download the examples from the Ansys Optics Application Gallery (Apps) website.
- The topic ‘Error in Opening Lumerical FDTD Interface’ is closed to new replies.
Ansys Innovation Space
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Help for qINTERCONNECT
- Trapezoidal ring
- Issues with getting result from interconnent analysis script
- Topology Optimization Error
- Edge Coupler EME Example Issue
- How to measure transmission coefficients on a given plane .
543
523
225
209
