Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Issues with Geometry Selections and Local Sizing in ANSYS Fluent › Reply To: Issues with Geometry Selections and Local Sizing in ANSYS Fluent
Subject: Re: Issue with Named Selections in Fluent Meshing
Thank you for your response and clarification. I appreciate your prompt assistance.
I’d like to bring to your attention a specific issue I’ve been facing:
In SpaceClaim, I’ve meticulously assigned named selections for bodies, faces, and edges within my geometry.
Upon importing this geometry into Fluent Meshing, I’ve noticed that the named selections for bodies and faces are correctly imported.
However, there seems to be a discrepancy when it comes to the named selection assigned for edges. It appears that this particular named selection for edges is not being carried over to Fluent Meshing.
To provide a clearer understanding of this issue, I have attached images from SpaceClaim in this reply and images from Fluent with the earlier one for your reference. These images should help illustrate the disparity in named selection import.
Your guidance in resolving this inconsistency would be greatly appreciated. I look forward to your insights and any suggestions you may have.
Thank you once again for your assistance.
Best regards,
Paul
