Electronics
Electronics
Calculation of Stator Tooth Force
    • 841563439
      When calculating the radial force of the motor teeth (multiple single teeth) and performing FFT decomposition, in order to accurately obtain the spatial order and time frequency order, should the whole tooth or only the tip part or other parts be taken?
    • 841563439
      I would like to know which part of the tooth is the most suitable in the picture above?Thank you! @Timos
    • Timos
      Hello Peter, I answered in Radial force of the motor teeth (ansys.com)
  • The topic ‘Calculation of Stator Tooth Force’ is closed to new replies.
