Electronics
Electronics
Alter an X and Z axis without altering the Y axis in HFSS?
    • imtiaz
      Hello. I want to change the x and z axis in HFSS [keeping the location the same]! What are the euler angle, phi, theta, and psi values for that one? Could you help me?
    • dushyant.marathe
      Hi Imtiaz,
      Thanks for posting your query on Ansys Learning Forum !
      You can change X and Z axis by changing angle Theta in above definition. Please try changing Theta value to 45 degree or 90 degree and this should change the X and Z axis keeping Y in same direction.
      Thanks.
  • The topic ‘Alter an X and Z axis without altering the Y axis in HFSS?’ is closed to new replies.
