September 10, 2023 at 1:54 pm
Yuanyuan Xiao
Ansys Employee -
September 10, 2023 at 1:56 pm
Yuanyuan Xiao
Ansys Employee在Fluent里获取压力梯度的方法如下:在计算之前输入命令solve/set/expert后回车,然后根据提示输入yes。如下图所示。
> solve/set/expert
Save cell residuals for post-processing? [no] yes
Keep temporary solver memory from being freed? [no] yes
Allow selection of all applicable discretization schemes? [no] yes
这样,计算结束后就可以在后处理中看到压力梯度这个参数。如下图显示的是某内流场某截面压力云图和Y方向的压力梯度。
- 主题 ‘Fluent里如何获取压力梯度?’ 已关闭新回复.
- Application of EDC occurs flame extinguishing
- Please help me check if there are any issues with the UDF.
- Difficulty in Complex Source Term Linearization
- Must EDC model need an initial flow field?
- Negative droplet growth rate in Fluent wet steam model
- Please help me analyze the multiphase flow model for the phase change of liquid
- Energy Source Term formulation for multi-component condensation
- Compile the UDF code and apply it to the DPM.
1306
