Importing final data on Fluent disabled
    • pcaicedo
      Hi all,
      I am trying to import final data from a cluster into Fluent. I have read that is possible to import as final results and the thick green is activated which means that I can use to keep working and manipulating the data; however, the browse button is disabled. If somebody knows if I need to activate something else, or do another step, that would be great.
      Import problem
      Thanks,
      Paul
    • Keyur Kanade
      Instead of Analysis System, please use Component System. Please use Fluent in Component System and check if it is available.
      Keyur
    • pcaicedo
      Hello Keyur,
      Thanks for the answer. I already tried that but doesn't work.
      Paul
    • Keyur Kanade
      Please right click on set up.
      Keyur
  • The topic ‘Importing final data on Fluent disabled’ is closed to new replies.
