Exporting contour data to matlab
    • birbara2
      Hello, Can I export contour data to matlab? It doesn't have to be as much high resolution as the mesh.
      Thanks
    • raul.raghav
      Assuming that you're using Fluent, there two ways of doing it:
      1. From Fluent:
      File > Export > Solution Data; File Type: ASCII, and select the appropriate contour plane with the specific contour variable of interest along with the plane coordinate axes. This will export the data into a csv file which can be imported in MATLAB.
      2. From CFD-Post:
      File > Export > Export...; Type: Generic, and select the required surface with the variable of interest. This will create a csv file which can be imported into MATLAB. If your mesh is too fine and if you don't need all the data, you can "Insert > Point Cloud" at the selected surface which the required point density and you can export this Point Cloud the same way as mentioned earlier.
    • sailesh1312
      But what if we want force as our desired variable?n
    • Yvette Law
      Hi there, how to make it process automatically so I dont need to open the case one by one ?
      Yes and no. You will need to open the case & data, but with journals you can automate the whole process.
Viewing 4 reply threads
  • The topic ‘Exporting contour data to matlab’ is closed to new replies.
