Ansys Products
Ansys Products
error: this is a post-processing only executable and Skip the fluent launcher
    • haibin wu
      I want to calculate the case, but it prompted me with the error in the following figure. After understanding it, I learned that I need to set it in the fluent launcher. However, since I previously set the fluent launcher to skip, I now run fluent without a fluent launcher. I directly enter the fluent messaging interface. How can I restore the settings and pop up the fluent launcher every time I start it?
    • haibin wu
      I got it, I have modified the "launcher.2022R2.ini" under C:\Users\Administrator\AppData\Roaming\Launcher to "launcher.2022R2.ini.old". Then reopen the fluent, and the fluent launcher will appear again, and a file named "launcher.2022R2.ini" will be generated again.
    • supreetha.j
      Hello Haibin,
      Glad you were able to resolve this.
  • The topic ‘error: this is a post-processing only executable and Skip the fluent launcher’ is closed to new replies.
