August 24, 2023 at 10:04 am
August 24, 2023 at 7:21 pmGuilin SunAnsys Employee
Most likely the simulation time is too small. Please use 100 times what you used. Do not worry about the estimated time as it will terminate after fulfilling the autoshutoff min and will stop early. If it stops at 100% it means the simulation time is too small.
You can place a time monitor at the same location and check if the time signal completely decays.
BTW: usually you do not need to use single frequency, as the source is a pulse in most of the times. The frequency domain result is obtained from the Fourier transform of time signal. If you have questions regarding to this please write a new post.
August 26, 2023 at 10:28 amSAURAV GAUTAMSubscriber
Thank you,
could you give more suggestions for simulating big structure in range 0.5 to 1 mm as simulation is taking long time. my goal is to find out transmission ration in doped silicon film.
August 28, 2023 at 8:39 pmGuilin SunAnsys Employee
For 1100 X 1900 X 380 mm it is too large for common workstation or cloud to handle at um wavelengh due to hardware limitation and other factors.
If the cross section is relatively small, but the simulation is long along propagation such as metalens, it can simulate only a small distance and the result can be calculated using farfieldexact:
https://optics.ansys.com/hc/en-us/articles/360042160473-Focusing-with-a-single-subwavelength-aperture
https://optics.ansys.com/hc/en-us/articles/360042160493-Bull-s-eye-aperture (please check the script inside the analysis group)
Depending on the frequency points you want, the farfieldexact might be a little slow.
If the cross section is large, you can also refer to the above examples but now the challenge is, you may need a lot of memory and the simulation is slow.
Baiscally the simulation will need to mesh the simulation space into grids and the time step is limited by the smallest mesh size, so for large dimensions more memory and longer simulation time are normal. If your computer is powerful enough, you can use as many as processes (cores) as possible, limited by your license.
- The topic ‘zero transmittance for .38 mm thick film at 1100 nm wavelength’ is closed to new replies.
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Trapezoidal ring
- Help for qINTERCONNECT
- Issues with getting result from interconnent analysis script
- Topology Optimization Error
- Edge Coupler EME Example Issue
- The two modes overlap the integral
1191
513
488
225
209
