August 19, 2023 at 8:07 pm
Vedant Sane
SubscriberHello,
I am basically faing the issue with proper meshing for 3D-Litz wire in Maxwell.
I used the following mesh settings:
As you can see in the above image, mesh quality is actually good at the bends. However, it is not meshing properly on the straight curvilinear surface and on the cross-sectional faces of the wires. I hv also tried meshing with skin depth but it does not seems to be work out. Any inputs for this problem would be much appreciated. Thanks!
August 21, 2023 at 12:11 pm
Ivonne Marti
Ansys EmployeeHello Vedant,
The Surface Approximation mesh operation allows you to control the mesh element size on the surface of the object. If I look the “bad” mesh, I can see that you are pointing the inner part of the cable. So, to control the mesh element size inside the object you should use the Inside Selection/Length Based mesh operation (see image below). I would suggest combining both mesh operations in order to get a “good” mesh. Ivonne
August 21, 2023 at 1:17 pm
Vedant Sane
SubscriberHello Ivonne,
I actually tried meshing with inside selection. However, it does not seem to work. Is there any way by which I can send you the model? Would it be possible for you to have a look at it?
Thanks!
August 21, 2023 at 2:15 pm
Ivonne Marti
If you want that we check the model, then you need to open a support ticket. We will be more than happy to help you.
Kind regards
Ivonne
August 24, 2023 at 7:51 pm
Vedant Sane
Can you pls guide me how to raise a support ticket?
August 25, 2023 at 11:21 am
- The topic ‘Meshing problem for circular and twisted geometries in Maxwell’ is closed to new replies.
5054
1764
1387
1248
