3D Design
3D Design
Boolean feature
    • monicaagabriela
      I want to follow this youtube tutorial:
      The only issue is that I cannot find the Boolean feature in Ansys 19.0. Can someone help me? What should I do?
      Kind regards,
      Monica
    • Keyur Kanade
      Its there under Create --> Boolean.
      Can you please insert image of what you can see under Create option.
      Keyur
    • monicaagabriela
      I cannot find it. Please see the picture attached.
    • monicaagabriela
      I haven't got any "create" in my toolbar.
    • Keyur Kanade
      This is SpaceClaim.
      In this, you can use Combine tool under Design tab.
      Keyur
    • monicaagabriela
      Thank you! It opens automatically in SpaceClaim when I click on "Geometry" -> "Edit" in Workbench. Can I change it? I should mention that I am a beginner. Thank you so much!
    • Keyur Kanade
      It should give as following.
      Once you open Design Modeler, you can import file in the session using File menu in DM.
      Keyur
    • monicaagabriela
      Should Design Modeler be downloaded separately? Thank you!
    • Keyur Kanade
      DM need not be installed separately. It should get installed with default installation. Can you please try reinstalling it.
      Also you can continue operations in SpaceClaim instead of DM. SpaceClaim is also very user friendly. You will need to use only Combine tool for boolean operations. I would recommend you to go ahead with SpaceClaim. You would love it.
      Keyur
    • tsiriaks
      Hi Monica,
      Are you using the Free ANSYS Student version or some paid academic/commercial license ?
      I'm guessing that the latter would be the case here. It's likely that you have a licensing issue.
      In this case, check if you have licenses for ANSYS Design Modeler.
      You can try this command in CMD Prompt (change your installation path accordingly)
      “C:Program FilesANSYS IncShared FilesLicensingwinx64ansysli_util” -checkout ANS_DM
      Note: Copy the entire thing including quote ""
      Please capture the screenshot of the output and put it in your post here.
      Thank you,
      Win
    • sumankumar
      sir I created airfoil with boundary but in meshing I am only getting airfoil! any solution
      @sumankumar, please open a New Discussion.
    • firdausghani
      Hello, I want to ask how do I Boolean whole parts of my modelnI want to model my uav modelnwhen I select, it only selects the wing and the tailn
      please open a New Discussion.nWhen you do, please insert some images to show the problem you are having.nSay what version of ANSYS you are using, say what CAD system created the UAV geometry, say what file format you exported from your CAD system, say which ANSYS app you are using: SpaceClaim or DesignModeler.n
    • Jiri
      Hello.nDecember 22,2020nThis is addressed to monicagabriela or anyone else, who can answer my question.nI am interested t know, how did you managed to upload video to the page> nI tried to upload mp4 video ( mp4 being the mot common format for MS Widows)...but the system rejected it with message it doesn't conform to the extensions allowed and then list of extensions was shown, which were (I believe) only a picture formats...nn
Viewing 14 reply threads
  • The topic ‘Boolean feature’ is closed to new replies.
