September 23, 2022 at 2:17 am
Sagar Patil
SubscriberHi DSL Support Team,
We have updated to version Discovery 2022 R2 & we are exploring it to suit the different requirement. We have overall gone through tutorials access with reg. mail ID. but due to new version we are not able to cope with steps in tutorials vs latest DSL.
Can you please share the DSL 2022 R2 guide & Bolt Flange Joint Gasket analysis tutorials if available with you.
Note: we are facing lot of issue after upgrading to latest version 2022 R2.
1) After opening Creo files directly opening data in Creo instead DSL
2) Lic not getting for ansys user etc.
Please do the needful
September 23, 2022 at 4:06 am
Charudatta Bandgar
SubscriberHello SagarLive
I do not have a tutorial for this, but please find the video I created explaining how to do a bolted joint analysis. You can also go through this knowledge material, and try the run there. Or go through these documentations to understand how to define bolt preload or use bolt assign tool.Â
SagarLive said:
1) After opening Creo files directly opening data in Creo instead DSLLet me check this with the team.
SagarLive said:
2) Lic not getting for ansys user etc. What error are you getting for them?
​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​​-
September 23, 2022 at 4:38 am
September 23, 2022 at 4:39 am
Sagar Patil
SubscriberSagarLiveÂ
Some snaps with Error messages, we have couple of similar error messages with us
September 23, 2022 at 6:30 am
Charudatta Bandgar
SubscriberSagarLive You are getting this error after applying the bolt preload? When did you get this error/after what operations?
September 26, 2022 at 4:54 am
September 26, 2022 at 5:32 am
Charudatta Bandgar
SubscriberSagarLive Do you face data loss after you select save as new version?
Regards.
September 26, 2022 at 8:01 am
Sagar Patil
SubscriberCharudatta BandgarÂ
We opened previous version data in new version. We were facing the above error message
selected Exit Without Saving
September 23, 2022 at 4:16 am
Sagar Patil
Subscriberhttps://www.youtube.com/watch?v=-9Er8-_U4Ho
refer below link for bolted joint with Discovery AIM but latest version have different UI or clubed all application in one DSL so not able to get in details.
September 23, 2022 at 4:28 am
Charudatta Bandgar
The video I have attached explains bolt pretension that is possible in Discovery 2022R2. Please go through that.Â
September 23, 2022 at 6:20 am
Sagar Patil
ok thanks,
we were looking for gasket leakage analysis is it possible with DSL 20222. plz confirm
September 23, 2022 at 6:28 am
Charudatta Bandgar
SubscriberSagarLive I will have to check if that is possible, my understanding is it might not be possible directly as the rubber gasket would perhaps need non linear material properties and this will be fluid + structural simulation. Let me check and get back to you if there is a feasible way to do it.
Also, if it is possible for you to share the workflow you would use in other products that you generally use for this kind of simulation, I can provide a workaround that might be possible in Discovery.Â
September 29, 2022 at 8:57 am
chinmay.damle
Can be get the gasket simulation and its estimations in terms of local contact pressure values in sealing areas ?
- The topic ‘Product guide & tutorials as per 2022 R2 i.e. Bolt Flange Joint Gasket analysis etc’ is closed to new replies.
