Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Workbench loads without opening › Reply To: Workbench loads without opening
August 8, 2023 at 9:56 am
Rajeshwari Jadhav
Hi AMR,
Can you please check if any antivirus software is blocking the Ansys application?Â
- Go to START > Event Viewer > Expand the Windows Logs and choose Application. In application log check if any Error is shown when you launch the workbench.
Can you check while installation any error had occured?
- Goto the install.err, install_licconfig.err, install.log, install_licconfig.log logs. (C:\Program Files\ANSYS Inc)
Can you goto start menu and type %appdata%, rename the Ansys folder over there as Ansys.old and relaunch the application.
