August 7, 2023 at 4:26 pm
qiji ch
SubscriberI have reinstalled Microsoft's MPI program and the Luminary program, but the below error still occurs,The above error only occurs when I check 'report tangent vector field' in the RCWA solver, and the program can run normally when not checked.
Besides, I also want to ask,How can I obtain the following calculated values in the case study,’Visualize the '
">Ep' from the "xz_field" monitor results. Repeat the same for the radius value of '100' nm‘. Thank you very much for your helpE p -
August 7, 2023 at 4:38 pm
Dev
Ansys EmployeeHello,
Are you reffering to any of your previous forum question? Please copy the link here or reopen the same post.
Thank you
August 7, 2023 at 4:58 pm
qiji ch
SubscriberReference Cases:Small-Scale Metalens – Field Propagation – Ansys Optics,
Reference answer热量错误代码0xc0000005 (ansys.com)
August 7, 2023 at 5:00 pm
August 7, 2023 at 6:36 pm
Dev
The “tangent vector field” option should only be used with mesh refinement set to conformal variant 0, 1 or 2. That might be the reason you are getting error.
For the second question: Change the radious of “model” to 100 nm and rerun the simulation. Then visualize Ep from xz_filed. The results in website will be updated soon.
50 nm:
=======>'Ep”>Ep’ from the “xz_field”
100 nm:
Note: Try to post one question per post. It will be easy to resolve and avoid confusion in attached screenshots. Ansys Insight: Ansys Innovation Space–Forum and Feed
Thanks and regards
Devika
August 8, 2023 at 1:20 am
qiji ch
Subscriberthankyou so much ,i will fix my bad next time,thank u sir
August 8, 2023 at 1:27 am
Dev
Ansys EmployeeYou are welcome. Hope this resolve the issue. Thanks for using the forum.
Regards
devika
- The topic ‘When I reproduced RCWA Metalens reference case, I was prompted for an error’ is closed to new replies.
