Debugging analysis
    • Adisa
      Does someone has the link of debugging non-converging analysis. I read that nonlinear analysis (contact, material,geometry) causes more problem. I am looking for example of the Solution Output  with description what mean codes in the Solver Output  or explanation of messages which appear when analysis do not convergence. I did a few the non linear analysis and Peter has help me, but I want to see even more the examples. If somebody founds  the links or some tips for non linear analysis. Please tell me.
      Best regards.
    • Sandeep Medikonda
      Hi Adisa,
      I would recommend these resources:
      This article.
      https://www.youtube.com/watch?v=njb7PWyeaH8
      Contact document and this blog post by John Doyle.
      I am sure others can add to this but this is a very generic question and it often depends on the problem you are trying to solve.
      Sandeep
    • Adisa
      Thank you.
  • The topic ‘Debugging analysis’ is closed to new replies.
