Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Reverse flow problem › Reply To: Reverse flow problem
August 1, 2023 at 11:04 am
I set volume fraction of h20 to 0.005, o2 to 0.228 and rest is n2. The densities of the substance are constant and the possibility of condensation has not been enabled.
- When i use same BC but operating density ,,minimum average phase" for expamle contour of velocity are as image 1 and residual image 2.
- But when i use ,,mixture average density" solutions are different (image 3, and 4)
- As you can see The results are so different that they destroy the whole simulation.
