July 31, 2023 at 7:57 am
July 31, 2023 at 8:17 am
SRP
Ansys EmployeeHi,
Ensure that the mesh resolution is adequate near the two-phase interface, especially at regions where the contact angle is essential. A coarse mesh may not capture the contact angle behavior accurately.
For more details on contact angle, please refer to fluent theory guide: 14.3.9. Surface Tension and Adhesion (ansys.com)
Thank you.
July 31, 2023 at 8:25 am
Chinmaya Kumar Patra
SubscriberÂ
I have used finner mesh in the interface and as the instruction written in the 14.3.9. Surface Tension and Adhesion (ansys.com) i have used hexahedral meshes. I have selected the wall adhesion under the multiphase model and given a constant contact angle.
July 31, 2023 at 9:33 am
Forum ModeratorPlease can you post screen shots of the wall panel set up? Momentum & thermal plus anything else you set.Â
July 31, 2023 at 9:50 am
SubscriberÂ
July 31, 2023 at 10:21 am
Forum ModeratorNot the summary, the actual panel you used to set up the model.Â
July 31, 2023 at 10:33 am
Subscriberok i will send all the setup panel screenshot shortly
- The topic ‘Two phase flow contact angle’ is closed to new replies.
5824
1305
