July 30, 2023 at 6:06 pm
atavafi
SubscriberI am currently working with Ansys HFSS and encountering a challenge related to changing the default result folder location. Specifically, I would like to place the project files in one folder(*.aedt) while directing the simulation results to be stored in another folder. Has anyone faced a similar problem like this?
Thanks for your help!
July 31, 2023 at 3:10 pm
Aymen Mzoughi
Ansys EmployeeThis is not possible
September 28, 2023 at 9:30 am
Eira Jeremy
SubscriberTo change the default result folder location in Ansys HFSS, right-click on the "Results" folder, select "Properties," and change the "Result File Directory" under the "General" tab.
October 22, 2023 at 1:23 pm
Peter Brant
SubscriberTo change the default result folder location in Ansys HFSS, you can go to the "Project" tab, select "Project Options," and then under the "Directories" tab, specify the desired folder for simulation results storage.
November 8, 2023 at 3:08 am
lalisa leee
SubscriberThis post is quite beneficial. I am grateful that you have shared it with not only me but also the rest of the globe. papa's freezeria
- The topic ‘Changing the Result Folder Location in Ansys HFSS’ is closed to new replies.
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Core Loss in ANSYS MAXWELL Eddy Current solution
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- simplorer-maxwell
4663
1545
1386
1230
