July 29, 2023 at 2:57 pm
Bhavik Boghra
Subscriber I am not able to install student version software it gives below security message.
Request name electronics_desktop does not exist in the licensing pool.
System clock has been set back.
Feature
electronics_desktop
License path
C
\Users\BSQUARE\AppData\Local\Temp\\b3234973-4851-4799-b28e-f2ec201ebf90;
FlexNet Licensing error
-88,309 -
July 29, 2023 at 3:06 pm
August 1, 2023 at 11:21 am
Rajeshwari Jadhav
Forum ModeratorHi Bhavik,
Please scan through all the files in your PC and delete any files that are of past date and time.
August 1, 2023 at 11:26 am
Bhavik Boghra
SubscriberI am not getting you .. all the files are past dated. we can't make in future date
August 1, 2023 at 11:36 am
Rajeshwari Jadhav
Please scan through all the files on your PC and delete any files that are of future date and time.ÂYou can refer to this KM: #2046797 - Esterel - License: Why do I get an error (ansys.com)ÂWARNING: We advise that you consult with a qualified computer systems professional before making modifications to files. ANSYS cannot guarantee results from mistakes made while following these instructions. Therefore, use caution and proceed at your own risk.ÂError Message: System clock has been set backÂComments: FLEXlm checks the dates of files in certain directories. If it finds files that have dates into the future, the license key will not work.ÂResolution: Locate files that are dated into the future and change the date.ÂYou can search for file options under Windows search and select File explorer Options > View tab, select button for Show hidden files and folderÂUncheck box for Hide protected Operating System filesÂThen from Windows search, type search and select Windows search options > Choose the enhanced search option, remove any excluded folder (do an entire search)ÂYou can also specify date range starting from today to 2050 or so on. -
August 1, 2023 at 12:23 pm
Bhavik Boghra
Subscriberno any files are dated in future
August 1, 2023 at 12:53 pm
Rajeshwari Jadhav
Please check the system clock is/was not set to BACKWARDS.
August 1, 2023 at 12:58 pm
Bhavik Boghra
SubscriberNo System clock is all good. It set tu current timezone.
August 1, 2023 at 1:23 pm
Rajeshwari Jadhav
Please try OS reimagining.
- The topic ‘Problem while installing’ is closed to new replies.
4683
1565
1386
1242
