July 21, 2023 at 3:55 pm
Cathleen
SubscriberHi, I'm working on a model in ANSYS fluent, I went back into Design Modeler to make a change (adding a line of symmetry to reduce computation time) and all the options in the Concept and Tools drop down menus are greyed out.
I didn't have any problems making changes earlier so I don't know what changed. Haven't been able to find any similar posts. The model is added as frozen and I cleared the downstream mesh but still can't make changes to the Design Modeler. Is there a setting I need to change? Thank you!
July 21, 2023 at 4:02 pm
Cathleen
SubscriberFigured it out, I had added a Share Topology. I needed to delete that to make changes. Thanks
- The topic ‘Design Modeler Concept and tools options greyed out’ is closed to new replies.
