July 11, 2023 at 1:25 pm
Daylon Hester
SubscriberI have a patch array antenna with Jsurf plots generated at 4 input phases [0,90,180,270]deg. How can I export one of these plots as a csv or some file type that I could read into some other software to generate vector scalable graphics? Could I accomplish this with the fields calculator? I've struggled to find good resources for this.
July 12, 2023 at 6:49 pm
Faezeh Ladani
Ansys EmployeeHi Daylon,
Yes, you can do it using fields calculator. From the Output column, you can either "Export" the data on your desired grid. Or you can "Write" the data on mesh nodes of the surface you choose. We have detailed help document about fields calculator, you may just search for fields calculator in the online help or on the pdf go to Post Processing and Generating Reports 23-408.Â
- The topic ‘HFSS – Exporting Current Distribution Surface Plot as CSV’ is closed to new replies.
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
- Two way coupling for Maxwell and thermal problem
4607
1510
1386
1209
