Ansys Learning Forum Forums Discuss Simulation Electronics Node is not attached to any net Reply To: Node is not attached to any net
Nathan B
It appears there could be a pin in the pin group that has no net assignment. I would suggest that you look at the location given to see if this is the case. But it is hard to tell. If you can submit a service request, then that would be advisable.
