Ansys Learning Forum Forums Discuss Simulation Materials Solution not converging ( Fibre Push Out ) Reply To: Solution not converging ( Fibre Push Out )
mrife
agambhir_be20 can you show the applied displacement - setting it to zero means go back to the original location i.e. no displacement.  From the latest picture it looks like the bond is breaking at the 'top' (most positive Y location) of the fibre.  It seems like you are going in the right direction.
Mike
