DED Process (Add-on MECHANICAL) Help
    • Titouan Cougoulic
      I just start a new project on Additive Simulation and i have an ANSYS error i don't understand. I used the 2022 R2 version of ANSYS.
      I have create on the Workbench a "AM DED Process" link with my geometry like in picture below.
      I used the DED process add-on with a G-code. Clusters have been well created and all running good until I start the transient thermal solve. I used Ti-6Al-4V define in the technical data of ANSYS (Additve Manufacturing Materials). I followed the additive manufacturing user manual and I don't think I missed a step on Mechanical. Picture below to illustrate.
      And this error message appear :
      Can you explain why i have this error ? What does that mean ? Is it a licensing problem ?
      (I can send you more informations if you need to help me)
      Regards
      COUGOULIC Titouan
    • Nanda
      Hello Titouan,
      You're using mechanical premium license, can you reset license preferences to default and try running the solution again. Let us know if this doesn't help.
      Nanda.
      • Titouan Cougoulic
        Thanks to your answer.
        I try it and it diesn't work.
        But I think I don't have the good license to run it.
        I will try an activate element simulation.
        COUGOULIC Titouan.
  • The topic ‘DED Process (Add-on MECHANICAL) Help’ is closed to new replies.
