June 22, 2023 at 3:59 pm
Fadi Al
SubscriberHaving trouble loading an existing project where I was given the Workbench files with the _files folder and whenever I attempt to initialize generating the volume mesh, the progress gets stuck at 30% even with different min/max cell sizes. This is for Ansys Fluent R1 2023 and I am unsure if this is due to a hardware issue or not since the geometry contains millions of cells. My laptop has 6 cores - 12 threads @ 2.6 - 4.5 GHz and 16 GB RAM so I am wondering if upgrading to 64 GB of RAM would help or not. Thank you for the help.
June 26, 2023 at 5:27 am
Keyur Kanade
Ansys EmployeeHere are platform recommendations
Platform Support and Recommendations | Ansys
With 16GB you can generate around 40 to 45 M tet cells depending on the geometry complexity and sizing used.Â
Please go through help manual for more detailsÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
- The topic ‘[Volume mesh generation stuck]’ is closed to new replies.
