June 21, 2023 at 7:59 pm
Sharveen Anandaraja
SubscriberHow do i join and create a fillet with a hollow cylinder and a rectangle to make a holder?
June 23, 2023 at 2:12 pm
Ashish Khemka
Forum ModeratorHi Sharveen,
Did you try subtraction available under Boolean operations? Subtract cylinder body from rectangle to make fillet.
Ashish Khemka
June 23, 2023 at 2:26 pm
dlooman
Ansys EmployeeDid you try the AFILLT command? Keep in mind that the native APDL geometry creation features are not very robust.
June 23, 2023 at 3:44 pm
wrbulat
Ansys EmployeeImage above created by commands below. Create a cylindrical ring and subtract a torus from it.
fini/cleÂ/vie,1,1,1,1,1/vup,1,zÂa=0.100r1=0.020r2=0.025r_fillet=0.005Â/prep7bloc,-a/2,a/2,-a/2,a/2,,-acyli,r1,r2,,aÂcyli,r2,r2+r_fillet,,r_filletwpof,,,r_fillettoru,r_fillet,r2+r_filletvsbv,3,4vadd,allÂvploÂBillÂÂ
- The topic ‘Fillet with Ansys Mechanical APDL 2023’ is closed to new replies.
1891
1419
1305
