June 17, 2023 at 6:25 am
Deep Nath
SubscriberI am trying to develop structured mesh in propeller blade but unable to develop. in workbench I tried, but unstructred gives me a validted result but the y+ value is very high. Now, I need structured mesh, and I tried with icem surface mesh but still that smooth curves are not generating. Seeking your help in this direction.
June 19, 2023 at 2:11 pm
Forum ModeratorIf y+ is high what boundary layer settings did you use?Â
ICEM CFD is not a simple code to use, and using the blocking part is fairly advanced.Â
June 26, 2023 at 6:41 am
Deep Nath
SubscriberThanks Rob,
Actually I started developing mesh in ICEM and somehow I developed in ICEM, a structured mesh. But yes, it was bit tricky. But thanks for your reply.
June 19, 2023 at 2:17 pm
C N
Ansys EmployeeHello Deep,
I recommend you to first take a cross section of the propellor blade so that you get a airfoil kind of geometry in design modeller and then create c mesh domain and then in ansys meshing through mapped face meshing and edge sizing create a conformal mesh . I have attached the AIC course link for your reference with detailed information.
Mesh — Lesson 4 - ANSYS Innovation Courses
I hope this solves your problem.
Thanks,
Chaitanya Natraj
June 26, 2023 at 6:44 am
Deep Nath
SubscriberThanks CN,
I have started develpoing mesh in ICEm and somehow it is coming a structured one. Still if I find more difficulties I'll look into design modeller. And thanks for sharing this video..yes, this option is a good one. I'll try it if needed.
Thanks
Nath
- The topic ‘Propeller blade meshing’ is closed to new replies.
- affinity not set
3872
1414
1241
1118
1015
