June 5, 2023 at 2:26 pm
BALA
SubscriberI am trying to do hexa dominant mesh for that i have splitted a body and used a shared topology option , but whenever i use shared topology instead of Contact it doesnt create the mesh. Multizone option does work when i keep hexa core as setting. What can be possible reason everytimes this happens. I feel the share topology option create some imprint on the geometry will that be Reason or something else?
June 6, 2023 at 12:07 pm
Nanda
Ansys EmployeeÂ
Hello Bala,
What are the error messages generated by the solver? Here’s a simple geometry I tried to mesh without and with shared topology respectively:
Shared topology merges the pair(s) of common faces between bodies into a single set of common faces (2 faces become 1 face). The shared faces belong to both of the neighboring bodies. When meshing these types of multibody parts, the mesh at the interface will be conformal. When I hide the cylindrical bar, we can see how mesh transforms to match with other body nodes:
Here’s an Ansys help link, which will give more information on how shared topology works:
Conformal Meshing Within a Part (ansys.com)
Nanda.
June 7, 2023 at 12:46 pm
BALA
SubscriberThanks for the reply. here , in the first pic the hexa dominant mesh cretaed on both componnents but when you used shared toplogy it didnt make hexa mesh on one component, I want both compnent meshed in hexa that is happening in my case. I am getting some error like match face is not found etc.Â
Aslo why I am not able to accsess the conformal meshing link that you have shared.Â
June 7, 2023 at 1:17 pm
Nanda
Ansys EmployeeHello Bala,
For the same model, using shared topology, the solver by default generates tets. But when I force it to "Hex dominant", I face no issues here. Here are the screenshots:
Here's how you can access the Ansys Online Help from within the Ansys Student products:
- Open Ansys Workbench (or any other Ansys product) and go to Help > Ansys Workbench Help. A browser window will open.
- Copy the link to the Ansys Online Help from the post on the Ansys Learning Forum.
- Paste the link into the address bar of the browser window opened in step 1, and you'll be able to access the desired page.
- The topic ‘Hexa Dominant Mesh issue’ is closed to new replies.
6344
