May 30, 2023 at 7:57 pm
ChiDB
SubscriberSalve,sto modellando una trave in c.a. su ansys workbench, mi è stato consigliato di disegnarla su autocad e indicare le armature come linee per poi dargli la sezione. Però quando lo esporto in formato iges e lo apro in ansys nel modello riesco a vedere solo il solido e non le linee,come posso fare per riuscire a visualizzarle o a disegnarle?
May 31, 2023 at 7:42 am
ashish.khemka
Forum ModeratorTranslated version:Â
Hi, I'm modeling a beam in c.a. on ansys workbench, I was advised to draw it on autocad and indicate the reinforcements
as lines and then give it the section. But when I export it in iges format and open it in ansys in the model I can only
see the solid and not the lines, how can I manage to view or draw them? -
May 31, 2023 at 2:02 pm
Gary_S
Ansys EmployeeÂ
On the Project schematic, right click on Geometry > Properties > Line Bodies (Enable)
Line Bodies should import into Mechanical. Note that the Corss Sections are not assigned and not defined.
Right Click on the Model Branch > Insert > Cross Sections > Select and define a cross section as needed.
- The topic ‘trave su ansys workbench’ is closed to new replies.
